[Gdal-dev] OGRDataSource::ExecuteSQL() method returning inaccurate results
Chapman, Martin MChapman at sanz.com
Wed May 12 13:05:56 EDT 2004
Frank,
Ok, thanks.  I will make the changes as appropriate.
Martin
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Wednesday, May 12, 2004 11:03 AM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] OGRDataSource::ExecuteSQL() method returning
inaccurate results
Chapman, Martin wrote:
> Frank,
> Thanks for the quick answer.  I just replied to my own question saying
> that I found the error.  It was in my code (as usual).  I was passing
> in the x,y points as y,x... so the filter does work.  You are correct
> that the orange box is my aoi rectangle.
> I did notice what you mentioned below about using the MBR of the
> feature.  I know how to write the intersection functions needed to
> filter n-gons, do you think it would be difficult to modify the
> ExecuteSQL to use the geometry instead of the MBR for the filtering?
> If you don't think that would be hard, what source code file would I
> make the mod in?  Or, has someone done that already?
Martin,
I think the thing to do would be to implement the
OGRGeometry::Intersect() method properly.  But note that this implies
being able to handle any two geometry types not just polygons against
polygon.
Also, if you do this, please ensure that the MBR pre-test is kept in
place to quickly handle some cases.  In fact, a special case for testing
against a rectangular polygon would also likely be worthwhile.
The current OGRGeometry::Intersect() implementation is in
gdal/ogr/ogrgeometry.cpp.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
