[Gdal-dev] how to extract data from OGR
Jacob Bensabat
jbensabat at ewre.com
Thu May 13 10:16:25 EDT 2004
Hello
I have started to use gdal and OGR and I have the following question,
I am loading a mapinfo map into a OGR structure, and I would like to be able to access all its components (lines, polygon, points ).
The problem is that except functions like DumpReadable, I do not see any public method in the code
that allows access to the data.
Am I missing something ? Is there a way to get to the data ?
an example (s) or pointer to examples would be very welcome.
thanks
jac.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040513/0b0b7c4b/attachment.html
