[Gdal-dev] Problems compiling GDAL
Michael Crider
mcrider at hoecoop.org
Thu May 20 10:32:24 EDT 2004
I am attempting to install GDAL 1.2.0 with MrSID for use with Thuban on
RedHat 8. I downloaded the MrSID DSDK 3.1.10 from
http://www.lizardtech.com/partners/dsdk/mrsid and copied the expanded
files to the same directory where I expanded GDAL. configure ran
without any complaints (./configure
--with-mrsid=/usr/local/Downloads/thuban/Linux_DSDK
--with-static-proj4=/usr --without-ogr). When I ran make, I got a long
series of messages similar to:
/usr/local/Downloads/thuban/gdal-1.2.0/.libs/libgdal.so: undefined
reference to `LizardTech::MetadataValue::operator unsigned short() const'
This is followed by:
collect2: ld returned 1 exit status
make[1]: *** [gdalinfo] Error 1
make[1]: Leaving directory `/usr/local/Downloads/thuban/gdal-1.2.0/apps'
make: *** [apps-target] Error 2
Is everything normal here or am I doing something wrong? Any suggestions?
