[Gdal-dev] Label Styles and MapInfo Formats
Frank Warmerdam
warmerdam at pobox.com
Tue May 25 17:21:22 EDT 2004
L Pool wrote:
> Allo Frank,
> The Vector Maps I'm currently working with are indeed in MapInfo format.
> This issue isn't really more than just an irritation - if you come across
> this problem when next you use Style Tools and MapInfo format Vector Maps,
> let me know if you get the same problem. For now I can just look for Text
> and extract it directly from the OGRField.
Louis,
If you can submit a bug report via Bugzilla it might be that there is a
bug that can be corrected at some point.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
