[Gdal-dev] Re: MinGW & GDAL: "[Linker error] undefined reference..."
Norman Vine nhv at cape.com
Thu May 27 04:12:21 EDT 2004
J.Krueger writes:
> Norman Vine wrote:
> >>  "[Linker error] undefined reference to `GDALAllRegister'"
> >>  "[Linker error] undefined reference to `GDALOpen'"
> > What is the command you are using to link the program
> > Note Win32 does not allow undefined symbols so the order of the libraries
> > presented to the linker is important
> Here's the Makefile Dev-C++ is creating:
> LIBS =  -L"C:/Dev-Cpp/lib" -L"C:/Dev-Cpp/gdal/lib"
I have never used Dev-C++ so I don't know exactly how
you enter this into the IDE but you need to link against libgdal
i.e. the link LIBS should be something like
LIBS =  -L"C:/Dev-Cpp/lib" -L"C:/Dev-Cpp/gdal/lib" -lgdal
HTH
Norman
