[ms4w-users] Re: [Gdal-dev] s57 support
Tyler Mitchell TMitchell at lignum.com
Fri May 28 15:36:10 EDT 2004
That did the trick Frank, thanks.
ms4w-users-bounces at lists.maptools.org wrote on 05/28/2004 11:55:01 AM:
> Tyler Mitchell wrote:
> > Does anyone know if s57 via ogr support is built into the latest ms4w.
I
> > got it working last night on linux but can't seem to get it working at
all
> > on a windows environment.
> > Error looks like the following, as opposed to the file not found
error:
> > msDrawMap(): Image handling error. Failed to draw layer named 's57'.
> > msOGRFileOpen(): OGR error. GetLayer( 9) failed for OGR connection
> > `data/s57/US1PO02M.000, 9'.
> > msAddImageSymbol(): Unable to access file. Error opening image file
> > /ms4w/apache/htdocs/mapserver/workshop/ogr-pen-6.
> > /ms4w/apache/htdocs/mapserver/workshop/mapinfo-pen-14.
> > /ms4w/apache/htdocs/mapserver/workshop/default-circle
> Tyler,
> It is likely the problem is related to finding the S57 support .csv
files.
> If the S57 reader cannot find s57objectclasses.csv and s57attributes.csv
then
> it will just provide a generic layer for each gross geometry type
instead of
> splitting things down by object class and you will get this sort of
issue
> trying to fetch a layer by number.
> You will likely need to set the GDAL_DATA environment variable to point
to
> the directory with the files in question.  If your MS4W is recent enough
> (4.2) you can likely do this within your mapfile something like the
following:
>    CONFIG GDAL_DATA "C:\gdal\data"
> Ideally MS4W would take care of all of this somehow.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> ms4w-users mailing list
> ms4w-users at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/ms4w-users
