[Gdal-dev] ENVI and raster attributes/color support
Frank Warmerdam
warmerdam at pobox.com
Tue Nov 2 15:23:39 EST 2004
Markus Neteler wrote:
> Hi,
> I have written (hope I got it right) a BSQ header file
> for
> http://glcf.umiacs.umd.edu/data/landcover/data.shtml
> AVHRR Global Land Cover Classification
> The attached file is a header file for "gl-latlong-1km-landcover.bsq.gz" from:
> ftp://ftp.glcf.umiacs.umd.edu/glcf/Global_Land_Cover/Global/gl-latlong-1km-landcover/
> My question is if support could be added to GDAL to read
> the color table and the raster attributes so that I could
> generate a more GIS convenient IMG file or whatever.
> Or is it a complicated thing (or "quota exceeded" for me :-)?
Markus,
I have implemented support for reading the "class lookup" as a colormap for
the first band, and capturing the "class names" as category names returned
by the GDAL GetCategoryNames() method.
I doubt the class/category names will do you much good as I am unaware of any
utility other than gdalinfo that does anything with category names.
warmerda at gdal2200[523]% gdalinfo *.bsq
Driver: ENVI/ENVI .hdr Labelled
Size is 43200, 21600
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AXIS["Lat",NORTH],
AXIS["Long",EAST],
AUTHORITY["EPSG","4326"]]
Origin = (-180.000000,90.000000)
Pixel Size = (0.00833333,-0.00833333)
Corner Coordinates:
Upper Left (-180.0000000, 90.0000000) (180d 0'0.00"W, 90d 0'0.00"N)
Lower Left (-180.0000000, -90.0000000) (180d 0'0.00"W, 90d 0'0.00"S)
Upper Right ( 180.0000000, 90.0000000) (180d 0'0.00"E, 90d 0'0.00"N)
Lower Right ( 180.0000000, -90.0000000) (180d 0'0.00"E, 90d 0'0.00"S)
Center ( -0.0000000, 0.0000000) ( 0d 0'0.00"W, 0d 0'0.00"N)
Band 1 Block=43200x1 Type=Byte, ColorInterp=Palette
Description = global land cover file 1km
Categories:
0: Water_and_Goode_s_interrupted_space
1: Evergreen_Needleleaf_Forest
2: Evergreen_Broadleaf_Forest
3: Deciduous_Needleleaf_Forest
4: Deciduous_Broadleaf_Forest
5: Mixed_Forest
6: Woodland
7: Wooded_Grassland
8: Closed_Shrubland
9: Open_Shrubland
10: Grassland
11: Cropland
12: Bare_Ground
13: Urban_and_Built-up
Color Table (RGB with 14 entries)
0: 0,0,0,255
1: 1,100,0,255
2: 1,130,0,255
3: 151,191,71,255
4: 2,220,0,255
5: 0,255,0,255
6: 146,174,47,255
7: 220,206,0,255
8: 255,173,0,255
9: 255,251,195,255
10: 140,72,9,255
11: 247,165,255,255
12: 255,199,174,255
13: 0,255,255,255
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
