[Gdal-dev] No python support for x86_64 with kakadu?
Chris Hodgson chodgson at refractions.net
Tue Nov 2 16:02:35 EST 2004
>BTW. what distribution do you use? has it full 64 bit userland? can you build
>a 32bit version of gdal and run a sort of emulation? do you need full 64 bit
>gdal?
I'm using Fedore Core 2... I don't know the answers to the other
questions...
However, this has become something of a non-issue for me right now - I
wanted the python support so that I could use gdal_merge.py to build an
overview layer of my big jpeg-2000 tileset. However, I have gotten
around this by using mapserver with a high-res output (25,000 pizels
square) and then making up a world file and and converting the output
.png file to another jpeg-2000 which I'm now using for the overview
layer. This worked quite nicely, takes a few hours of processing, but
it's done.
Perhaps we can just ignore this issue, at least until someone else runs
into the problem.
Later,
Chris
