[Gdal-dev] OGR SFS Specification and style of point features
ksa
ksa-nil5 at yandex.ru
Fri Nov 5 03:50:45 EST 2004
Hi, Frank, hi, Daniel.
I wrote to you some time ago about font name in style string for point
features. You answered, that there is no ability to get this information.
I have developed a patch (for OGR 1.2.3), which helps to get that
information. But it's implemented only for MapInfo files. (MIF/MID and
TAB).
And I tested it only for MapInfo files. But I think, that it does not have
effect for other formats (bad effect, of course :) ).
I suggest, it is nesessary to change OGR Simple Feature Style Specification
by adding new parameter in Symbol Tool parameter set. Parameter
'font name' ("f").
Do you think this is a good idea? I'd like to see my name in list of
developers of OGR. Do you think it is possible? :)
Patch is in attached file.
Sergey Karin.
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20041105/97b42588/OGRFeature-FontName.diff.obj
