[Gdal-dev] ERDAS LAN/GIS support in GDAL
Mon Nov 8 21:28:42 EST 2004
DaZoner wrote:
>I see that I can read ERDAS 7.4 GIS and LAN files using GDAL. But GDAL does
>not support writing of this format. Is there a technical reason as to why
>this format is not supported for write? (e.g. it supports 4 bit which could
>be problematic). Or is it simply a manpower issue.
DaZoner,
There is compelling reason why LAN/GIS export wasn't done but it was not
a requirement of
the client who needed the read support so I just did what was requested.
Best regards,
