[Gdal-dev] Enhancement to access Arc/Info Binrary Grid in zip file
Kevin Ruland kruland at ku.edu
Wed Nov 10 14:47:27 EST 2004
Frank,
Thanks much for the sanity check.  Random access writes would hurt.
About the only way for it to work effectively would be to unzip into
memory, modify, and rezip.
I was digging through the aigrid code and see that it manipulates file
pointers directly, so it would be a great effort to work it in even for
my prinicipal interest,  read-only access.
Kevin
Frank Warmerdam wrote:
> Kevin Ruland wrote:
>> I've been lurking for a little while and am a relatively new user of
>> the GDAL library.  Please excuse any "neubies" I might make.
>> I'm in the process of cataloging all of our raster datasets and am
>> troubled by the Arc/Info multiple file setup.  Keeping track of
>> multiple files is significantly harder than tracking them all in,
>> say, a zip file.  I was wondering if anyone has considered storing
>> these multi-resource formats in a container of some kind, what the
>> implications are, and if it would even be worthwile to persue.
> Kevin,
> I don't think it would be particularly easy to implement this though
> it is in theory doable, at
> least for one format at a time.
> One problem is that formats like Arc/Info binary coverages are random
> access, and in a zip
> file each file is compressed as one big stream.  That means if you
> want data from the middle
> of the file, you need to uncompress all the preceeding data (and
> discard it) to get the data
> you want.  In some cases this could completely hammer performance.
> While I sympathaize with your concern about managability of directory
> trees, I am doubtful
> it is practical from a work or a performance point of view to change
> most of the multi-file
> formats to support zipped version.
> Best regards.
