[Gdal-dev] gdalwarp nodata
Sat Nov 13 14:17:01 EST 2004
Frank Warmerdam wrote:
> OK I have attached a little script that takes in an RGB file, and outputs
> an RGBA file with alpha set to transparent(0) where the condition is
> met, and
> to opaque(255) where it isn't set.
Sorry .. this time I really attached it.
#!/usr/bin/env python
import gdal
import sys
import Numeric
try:
    src_file = sys.argv[1]
    dst_file = sys.argv[2]
except:
    print 'Usage: rgbamask.py <srcfile> <dstfile>'
    sys.exit(1)
# Open input file.
src_ds = gdal.Open( src_file )
# Create output file.
driver = gdal.GetDriverByName( 'GTiff' )
dst_ds = driver.Create( dst_file, src_ds.RasterXSize, src_ds.RasterYSize, 4 )
dst_ds.SetProjection( src_ds.GetProjection() )
dst_ds.SetGeoTransform( src_ds.GetGeoTransform() )
# Do the processing one scanline at a time.
gdal.TermProgress( 0.0 )
for iY in range(src_ds.RasterYSize):
    src_red = src_ds.GetRasterBand(1).ReadAsArray(0,iY,src_ds.RasterXSize,1)
    src_green = src_ds.GetRasterBand(2).ReadAsArray(0,iY,src_ds.RasterXSize,1)
    src_blue = src_ds.GetRasterBand(3).ReadAsArray(0,iY,src_ds.RasterXSize,1)
    # Set alpha to transparent (0) where our condition is met, otherwise,
    # set it to 255.
    alpha = Numeric.where(src_red==255 and src_green==255 and src_blue==255,
                          0,255)
    dst_ds.GetRasterBand(1).WriteArray(src_red,0,iY)
    dst_ds.GetRasterBand(2).WriteArray(src_green,0,iY)
    dst_ds.GetRasterBand(3).WriteArray(src_blue,0,iY)
    dst_ds.GetRasterBand(4).WriteArray(alpha,0,iY)
    gdal.TermProgress( (iY+1.0) / src_ds.RasterYSize )
dst_ds = None
