[Gdal-dev] Re: how to show the hdf file's subdataset's speacial
band?
wlx
wlx at mygis.org
Sun Nov 14 01:47:38 EST 2004
Hi Andrey,
I don't know how to use the second way to show a band's image.
For example, if I use the gdal_translate command,how to do it?
Sorry to trouble you.
Best regards,
LiangXu Wang
> > The 2-dimensional subdatasets will be read as single band images.
> > 3-dimensional subdatasets will be read as multiband ones.
> > Afterwards you can load any band using normal GDAL's API.
> > Yor application should have the two levels of file controls:
> > the first one to select a subdataset and the second one to select a
> > band(s) within that subdataset.
> > Andrey
> > Andrey V. Kiselev
> > Home phone: +7 812 5970603 ICQ# 26871517
> > Gdal-dev mailing list
> > Gdal-dev at xserve.flids.com
> > http://xserve.flids.com/mailman/listinfo/gdal-dev
