[Gdal-dev] Re: --with-grass
Mon Nov 15 13:35:47 EST 2004
Maciek Sieczka wrote:
> Hello!
> I tried to build gdal against --with-grass to enble the r.out.gdal for the
> first time.
> 1. built Gdal (CVS 2004_11_13) --without-grass
> 2. built Grass (CVS 2004_11_06) --with-gdal
> 3. make distclean in the Gdal dir, built --with-grass like following:
>     ./configure --with-hdf4 --without-ogdi --with-grass=/urs/local/grass55
> and got:
>     checking for G_asprintf in -lgrass_gis... no
>     configure: error: --with-grass=/urs/local/grass55 requested, but
>     libraries not found!
> Can somebody help me to sort it out?
Maciek,
I think Markus already answered the above part about needing either
GRASS 5.7 (for --with-grass) or libgrass (for --with-libgrass).
> BTW: why does "make uninstall" invoked in the source dir after the
> "./configure, make, make install" doesn't work? Should I give more detailed
> info?
GDAL does not have an uninstall target, and I am not really enthusiastic about
adding one.
Best regards,
