[Gdal-dev] HDF problems
Seppo Kaitala
seppo.kaitala at fimr.fi
Tue Nov 16 04:28:28 EST 2004
I am new with gdal library and I do not know,if it is working properly.
I installed FWTools-0.9.1 under Fedora C2.
I have downloaded hdf files from DAAC server
http://daac.gsfc.nasa.gov/data/datapool/ and I can open the files with
HDFLook software.
However, for further development I wold like to load HDF files directly
to GRASS 5.4 with gdal libraries.
So for testing I exported the geotif file from GRASS and run
>gdalinfo maa1km.tif
Driver: GTiff/GeoTIFF
Size is 2169, 1422
Coordinate System is `'
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 1422.0)
Upper Right ( 2169.0, 0.0)
Lower Right ( 2169.0, 1422.0)
Center ( 1084.5, 711.0)
Band 1 Block=2169x1 Type=Byte, ColorInterp=Red
Band 2 Block=2169x1 Type=Byte, ColorInterp=Green
Band 3 Block=2169x1 Type=Byte, ColorInterp=Blue
So as if it is working properly
But when I try
>gdalinfo GSUB1.A2001122.1045.003.2002343183413.hdf
ERROR 4: `GSUB1.A2001122.1045.003.2002343183413.hdf' not recognised as a
supported file format.
GDALOpen failed - 4
With HDFLook it works properly showing the information inter alia:
HDFLook_modis (Version 4.10B [HDF.4.2.r5])
Do I still miss some libraries, and how I would know that.
How I could get forward?
Best regards
Seppo Kaitala, Scientist, Ph.D.
Biological Oceanography
Finnish Institute of Marine Research
PO Box 33 (Lyypekinkuja 3 A)
FIN-00931 Helsinki, Finland
tel. +358-9-613941 fax +358-9-6139 4494
email: seppo.kaitala at fimr.fi
