[Gdal-dev] Problem compiling under VS.NET
Thom DeCarlo t.r.decarlo at larc.nasa.gov
Thu Nov 18 12:07:26 EST 2004
Ok, I think I found a problem. Something changed in frmts/gtiff/libtiff
between the time I grabbed the tarball on 12OCT04 and the tarball from
yesterday. The "#include <iostream.h>" was added to tiffio.h during that
month.
I found <iostream> in 4 different files within gdal, but <iostream.h> is
only in tiffio.h. Isn't mixing ANSI Standard and Non-ANSI libraries
verboten?
Can someone tell me what is needed to get the new version of gtiff to
compile?
Thanks,
Thom
Thom DeCarlo
       The squeaky wheel gets the grease.
     It is also the first one to be replaced.
> -----Original Message-----
> From: Thom DeCarlo
> Sent: Thursday, November 18, 2004 10:07 AM
> To: 'GDAL developers'
> Subject: RE: [Gdal-dev] Problem compiling under VS.NET
> Tried that. I've recently "upgraded" from VS6 to VS.NET and this might be
> the first time I've tried to recompile gdal using the new compiler.
> It looks like I don't have a full installation of the compiler. The old
> iostream libraries and headers (iostream.h, fstream.h, strstream.h, etc.)
> don't exist anywhere in my computer. The new, ANSI Standard headers
> (without
> the .h extension) are in the Vc7/include directory. But, of course, it's
> not
> as easy as simply removing the ".h" from the #include line. The compiler
> then complains about:
>    C++ exception handler used, but unwind semantics are not enabled.
> Specify
> /EHsc
> Any other ideas?
> Thom
> Thom DeCarlo
> If you love sausage or government, you should never
> witness the creation of either.     -Goethe
> > From: Chapman, Martin
> > Sent: Wednesday, November 17, 2004 7:37 PM
> > To: Thom DeCarlo; GDAL developers
> > Download the zip file for windows, unzip to c:\gdal, and change the
> > GDAL_HOME in the nmake.opt to c:\gdal.  Then run the compiler as
> > specified in the build instructions for windows on the gdal site.  Let
> > me know if that works.
> > Martin
> > From: Thom DeCarlo
> > Sent: Wednesday, November 17, 2004 2:20 PM
> > Subject: [Gdal-dev] Problem compiling under VS.NET
> > Hi all,
> > I downloaded last night's tarball and found that I cannot compile using
> > VS.NET'03. The crash occurs in frmts/gtiff
> > C:\SVS_DE~1\GDAL-C~2\frmts>cd gtiff   && nmake /NOLOGO /f makefile.vc
> >     cd ..
> >   cl /nologo /Ox /MD -I..\..\port -I..\..\ogr -I..\..\gcore -Ilibtiff
> >     -Ilibgeotiff /c geotiff.cpp
> > geotiff.cpp
> > libtiff\tiffio.h(498) : fatal error C1083: Cannot open include file:
> >     'iostream.h': No such file or directory
> > NMAKE : fatal error U1077: 'cl' : return code '0x2'
> > Stop.
> > I think the problem is iostream.h is now called iostream (with no
> > extension). There are many other similar changes. Can someone tell me
> > how to get this to compile with VS.NET?
> > Thanks,
> > Thom
