[Gdal-dev] Problem compiling under VS.NET
Thom DeCarlo
t.r.decarlo at larc.nasa.gov
Thu Nov 18 13:35:30 EST 2004
Curiouser and curiouser...
I commented out the offending section of tiffio.h and got gtiff to
successfully compile. But, it hit another snag further along in the build.
Within the frmts/vrt section the vrtwarped.cpp is including gdalwarper.h.
That file isn't in the include paths. It is in gdal/alg.
I added to the EXTRAFLAGS variable in frmts/vrt/makefile.vc
EXTRAFLAGS = -I..\raw -I..\..\alg
And this seems to have worked. (or, at least it compiled.)
Thom
OBTW, I cannot get to the maptools.org website to download a new tarball.
The MapTools.org homepage says they are recovering from an attack this
morning.
Thom DeCarlo
Man will occasionally stumble over the truth,
but most of the time he will pick himself up and continue.
-- Winston Chruchill
> -----Original Message-----
> From: Norman Vine [mailto:nhv at cape.com]
> Sent: Thursday, November 18, 2004 12:48 PM
> To: Thom DeCarlo
> Subject: RE: [Gdal-dev] Problem compiling under VS.NET
> Thom DeCarlo writes:
> > Ok, I think I found a problem. Something changed in frmts/gtiff/libtiff
> > between the time I grabbed the tarball on 12OCT04 and the tarball from
> > yesterday. The "#include <iostream.h>" was added to tiffio.h during that
> > month.
> > I found <iostream> in 4 different files within gdal, but <iostream.h> is
> > only in tiffio.h. Isn't mixing ANSI Standard and Non-ANSI libraries
> > verboten?
> > Can someone tell me what is needed to get the new version of gtiff to
> > compile?
> Hmm....
> My code repository is from CVS as of 14-Nov-2004
> and it looks to me as if one can comment out that section of tiffio.h
> as results of grepping my GDAL directory shows
> Found 0 lines with R-E "TIFFStream" in d:\src\gdal\**\*.c*
> Found 2 lines with R-E "TIFFStream" in d:\src\gdal\**\*.h*
> d:\src\gdal\frmts\gtiff\libtiff\tiffio.h: extern TIFF*
> TIFFStreamOpen(const char*, ostream *);
> TIFFStreamOpen(const char*, istream *);
> Norman
> ===== from end of tiffio.h =====
> #if defined(c_plusplus) || defined(__cplusplus)
> # include <iostream.h>
> extern TIFF* TIFFStreamOpen(const char*, ostream *);
> extern TIFF* TIFFStreamOpen(const char*, istream *);
> #endif
