[Gdal-dev] Re: HDF problems
Carl Anderson
carl.anderson at vadose.org
Sun Nov 21 19:38:09 EST 2004
> From: Seppo Kaitala <seppo.kaitala <at> fimr.fi>
> I am new with gdal library and I do not know,if it is working
> properly.
> I installed FWTools-0.9.1 under Fedora C2.
> I have downloaded hdf files from DAAC server
> http://daac.gsfc.nasa.gov/data/datapool/ and I can open the files
> with
> HDFLook software.
I do know that
HDF4_SDS:ASTER_L1B:
isn't working right in FWTools 0.9.1
revert back to
OpenEV_FW_linux_1.7.2.tar.gz
and see if your issues are taken care of.
FWTools-0.9.1 does not honor the geographic info in the ASTER L1B file
OpenEV_FW 1.7.2 does honor it.
Also if you have previously compiled GDAL or any of the other support
libraries you should call files from the $OPENEV_HOME/bin_safe or
$FWTools_HOME/bin_safe dir.
C.
