[Gdal-dev] Re: GDAL 1.2.4 Build problems on RH7.3 linux
Tue Nov 23 00:38:58 EST 2004
Lars Holm Loldrup wrote:
> Trying to build a 1.2.4 version, with the options:
> ./configure
>  --prefix=$installdir
>  --without-python
>  --with-xerces=$installdir
>  --with-pg=/usr/local/pgsql/bin/pg_config
>  --with-geos=$installdir/bin/geos-config
>  --with-static-proj4=$installdir
>  --with-png=$installdir
> The script ends up with following output:
> config.status: creating GDALmake.opt
> sed: file ./confstatnVtLBi/subs-3.sed line 15: Unterminated `s' command
> config.status: creating port/cpl_config.h
> config.status: port/cpl_config.h is unchanged
Lars,
This might have been addressed alread, but this is a bug with the mysql
support.  You can configure --without-mysql to fix it or upgrade to 1.2.5.
Sorry about that,
