[Gdal-dev] problem with gdal 1.2.5?
Frank Warmerdam
warmerdam at pobox.com
Tue Nov 23 14:09:42 EST 2004
Norman Barker wrote:
> Hi Frank,
> I have recompiled Proj 4.4.9 and added your fix but get the same error.
> I am using the GDAL 1.2.3 that comes with OpenEV on windows and
> that works fine. Do you have any other suggestions?
Norman,
Sorry, I really don't know why you would still get it. Are you sure
the right PROJ.DLL is being picked up at runtime?
I tried the command here on Linux and win32 and had no problem.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
