[Gdal-dev] OGR with Geos in Windows?
Frank Warmerdam
warmerdam at pobox.com
Wed Nov 24 12:59:46 EST 2004
Rodrigo Aceves wrote:
> I'm trying to build OGR (GDAL) in Windows, but I can't figure it out how.
> Any ideas?
Rodrigo,
Is your problem with building GDAL/OGR itself or specifically with including
geos support? GDAL/OGR building is covered briefly at:
http://gdal.org/gdal_building.html
I have never built with GEOS support on windows yet. To do so I imagine you
would need to ensure that HAVE_GEOS is defined (-DHAVE_GEOS=1 in OPTFLAGS
for instance), and that the directory above the geos include directory is
in the include path. Then link in the geos library (put it in ADD_LIBS
variable in nmake.opt).
As far as I know, geos itself doesn't have a vc makefile, so you may have
a bit of effort at that end.
I really should add it to my FWTools builds for windows at which time I
would add it more properly as an option in nmake.opt.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
