[Gdal-dev] GeoTiff and nodata values
Kor de Jong k.dejong at geog.uu.nl
Thu Nov 25 05:53:37 EST 2004
I am writing some tests for the PCRaster raster driver and have a question
about the nodata handling of the GeoTiff driver.
For one test I read several kinds of PCRaster files using the GDAL PCRaster
driver. Each dataset is written using CreateCopy and read again. This way I
want to check that a written copy of a PCRaster file equals the original.
When I use the PCRaster driver to create copies of the originals all goes
well.
Using the GeoTiff driver I noticed that for rasters in UINT1 (UInt8) and INT4
(Int32) all goes well too, but for data in REAL4 (Float32) the missing value
of the GeoTiff file is set to 0 instead of 1e-30 which is used by the
PCRaster driver. The cell values of the original PCRaster file and the
GeoTiff file do equal eachother, it is just that the nodata value of the
GeoTiff file is not set to the value used in the PCRaster driver. In the
other cases (UINT1, INT4), the nodata value is correctly copied into the
GeoTiff.
Does anyone know why the nodata value is handled differently by the GeoTiff
driver, depending on the type of the cell values?
Best regards,
Kor
