[Gdal-dev] Makefile problem with MingW
Norman Vine
nhv at cape.com
Fri Nov 26 14:18:54 EST 2004
Hi Frank
Is it possible to add a configure check for whether to use
cpl_vsil_win32.o
instead of
cpl_vsil_unix_stdio_64.o
for the MingW build
As it is one has to hand edit the $(GDAL)/port/GNUMakefile
when building with MSYS or MingW
probably easiest to do this by adding a new variable to
GDALmake.opt
say CPL_VSIL_STDIO
and then in the makefile
OBJ = cpl_conv.o cpl_error.o cpl_string.o cpl_vsisimple.o \
cplgetsymbol.o cpl_dir.o cpl_path.o cpl_csv.o cpl_findfile.o \
$(CPL_VSIL_STDIO).o cpl_minixml.o cpl_multiproc.o \
cpl_list.o
note: Cygwin wants to use the unix version
Thanks
Norman
