[Gdal-dev] Modifying OGR geometry in place
Petteri Packalen
packalen at cs.joensuu.fi
Mon Nov 29 03:19:37 EST 2004
Hi
I'm switching from shapelib to OGR and I don't understand how geometry can
be modified in place. My purpose is to modify z-values of the point file.
The current approach is as follows:
1. I create a copy of input file by using CopyDataSource(). This
will be the output file where z-value is modified.
2. I loop through the features by using GetNextFeature() method.
3. This is unclear for me. How can I fetch the geometry object from
feature such a way that I can manipulate it and write back to the
disk? Or is this even possible (or should I create a completely new
feature)?
It is also unclear for me that what will be the update mode of created
data source after CopyDataSource()?
Thanks in advance,
Petteri
Petteri Packalén "There are two major products that
University of Joensuu came out of Berkeley: LSD and UNIX.
Faculty of Forestry We don't believe this to be a
P.O. Box 111 coincidence." -- J.S. Anderson
80101 Joensuu
Finland "There still remains a question: Which
e-mail: packalen at cs.joensuu.fi caused the other?"
