[Gdal-dev] warp and translate problems
Chris Hodgson
chodgson at refractions.net
Wed Oct 6 17:07:39 EDT 2004
>> I think the real problem was that gdaltindex wasn't recognizing the
>> GeoJP2 georeferencing - it complained that my jp2 files weren't
>> georeferenced. However, they loaded just fine in ArcMap - wow, GeoJP2
>> must be a real standard if even ESRI recognizes it :-)
> Perhaps you have an old/incompatible gdaltindex? Does your gdalinfo
> properly report georeferencing?
There was actually only one file that gave this error, and I think the
original source was corrupt in some way... I don't think it's anything
to worry about as I've just created a couple of tile indexes of jp2s
using gdaltindex without any problems.
Chris
