[Gdal-dev] Windows build from CVS
Martin Daly
Martin.Daly at cadcorp.com
Fri Oct 8 05:38:56 EDT 2004
Frank,
I did a cvs update this morning, and the Windows build was broken. I
had to change two files as follows, both attached:
frmts\airsar\airsardataset.cpp
Lines 358-361 from:
M[M13] = byte[4] * fabs(byte[4]) * M[M11] / (127*127);
M[M14] = byte[5] * fabs(byte[5]) * M[M11] / (127*127);
M[M23] = byte[6] * fabs(byte[6]) * M[M11] / (127*127);
M[M24] = byte[7] * fabs(byte[7]) * M[M11] / (127*127);
To:
M[M13] = byte[4] * fabs((double) byte[4]) * M[M11] / (127*127);
M[M14] = byte[5] * fabs((double) byte[5]) * M[M11] / (127*127);
M[M23] = byte[6] * fabs((double) byte[6]) * M[M11] / (127*127);
M[M24] = byte[7] * fabs((double) byte[7]) * M[M11] / (127*127);
VC++ .NET has multiple fabs-s (float, double and long double),and can't
choose which one without a cast.
frmts\hdf4\hdf-eos\makefile.vc
This did not have CRLF endings, and nmake was choking on it as a result.
Regards,
Martin
Type: application/octet-stream
Desc: makefile.vc
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20041008/5664f223/makefile.obj
Desc: airsardataset.cpp
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20041008/5664f223/airsardataset.obj
