[Gdal-dev] Floating point pixel coordinates and scaling
Rolf Magnus ramagnus at kde.org
Wed Oct 13 13:15:11 EDT 2004
Hi!
I'm currently writing a moving map program for KDE that uses gdal. Basically,
I just use GDALDataSet::RasterIO in my paint event handler to get the pixels
that I need to redraw when some parts of my view get exposed. This is very
fast, even when I let gdal scale it on a slow PC.
Anyway, I've got one specific problem with the scaling. When the image is to
be scaled up, the input coordinates might not lie on an exact pixel boundary.
I would need a way to specify e.g.  that I want to start at pixel coordinates
200.125/150.25, which is not possible, because RasterIO wants integer
coordinates. I can work around that problem somehow, but I think it might be
a good idea to solve it in gdal itself. What do you people think about that?
