[Gdal-dev] gdalinfo
Ethan Alpert
ealpert at digitalglobe.com
Thu Oct 14 11:11:54 EDT 2004
Do you know the projection and coordinates? If so you can use
gdal_translate and gdal_warp to generate one but you have to know the
corner points of your image.
-e
-----Original Message-----
Sent: Thursday, October 14, 2004 6:58 AM
To: Ethan Alpert; gdal-dev at xserve.flids.com
Subject: RE: [Gdal-dev] gdalinfo
Did you create your own tfw file or find one? I do not seem to
have any
tfw files with my tif files. This is why I cannot find the
information I
want? Thanks again!
Todd
From: Ethan Alpert [mailto:ealpert at digitalglobe.com]
Sent: Wednesday, October 13, 2004 12:42 PM
To: Dobmeyer, Todd; gdal-dev at xserve.flids.com
Does the image come with a tfw? Your output suggests there's no
projection associated with your tif.
Here's what my gdalinfo looks like on GeoTiff's I create:
Driver: GTiff/GeoTIFF
Size is 1039, 3628
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235629972,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree (supplier to define
representation)",0.01745329251994328],
AUTHORITY["EPSG","4326"]]
Origin = (-105.220222,40.261786)
Pixel Size = (0.00020000,-0.00020000)
Corner Coordinates:
Upper Left (-105.2202222, 40.2617861) (105d13'12.80"W,
40d15'42.43"N)
Lower Left (-105.2202222, 39.5361861) (105d13'12.80"W,
39d32'10.27"N)
Upper Right (-105.0124222, 40.2617861) (105d 0'44.72"W,
40d15'42.43"N)
Lower Right (-105.0124222, 39.5361861) (105d 0'44.72"W,
39d32'10.27"N)
Center (-105.1163222, 39.8989861) (105d 6'58.76"W,
39d53'56.35"N)
Band 1 Block=1039x7 Type=Byte, ColorInterp=Red
Band 2 Block=1039x7 Type=Byte, ColorInterp=Green
Band 3 Block=1039x7 Type=Byte, ColorInterp=Blue
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20041014/b97ededb/attachment.html
