[Gdal-dev] DriverManager
Frank Warmerdam
warmerdam at pobox.com
Fri Oct 15 11:11:44 EDT 2004
Matthew Hanson wrote:
> Hi,
> When is the global DriverManager object created?
Matt,
It is created by the first call to GetGDALDriverManager(). This usually
happens in the all register function.
> I thought it would be
> created in the GDALAllRegister function. What I wanted to do is make the
> AllRegister function happen in the background in my wrapper.
> - If the AllRegister function has not been called will GetGDALDriverManager
> return a 0?
No, it never returns NULL.
> - The declaration for GetGDALDriverManager does not occur in gdal.h (but
> DestroyDriverManager does), but instead is in gdal_priv.h. Shouldn't it be
> in the C API header?
The driver manager class is a singleton, and so it's existance as a descrete
object is masked by the C API. There is little point in exposing it.
> - There's one global instance of DriverManager which (sorta) holds/manages
> one instance of GDALDriver for each format type. Does calling
> DestroyDriverManager end up destroying all these instances and deregistering
> all the drivers?
Yes.
> - I'm trying to figure out the C wrapper works, there's the gdal.h with the
> declarations, but how is it linked to the native C++ object functions?
Linked?
The gdal.h declares all the C API functions. The implementation of the
C functions is normally found in the source files right next to the
corresponding C++ method implementation. The produced GDAL DLL exports
the C and C++ interface.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
