[Gdal-dev] ogr2ogr Datum Shift
    Randy Page
    randy.page at terraverge.com
    Mon Oct 18 21:55:33 EDT 2004
Hi All,
I am using ogr2ogr to convert street data from GDT/Tiger format to PostGIS.
In the process, I would like to convert the data from GCS NAD27 to GCS
NAD83.   Below is a sample command line string I am using:
ogr2ogr -f PostgreSQL PG:"dbname=tiger host=localhost" d:\usa\06\06047
-where "cfcc like 'A%'" -lco OVERWRITE=yes -s_srs epsg:4267 -t_srs epsg:4269
-nln datumTest CompleteChain
When I execute this, I get the following error:
Error 1: failed to load NAD27-83 correction file
Failed to transform feature 46.
Error 1:  Terminationg translation prematurely after failed translation of
layer CompleteChain
Any suggestions as to what might be wrong here?
Thanks in advance,
Randy
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20041018/90e2a3e2/attachment.html
