[Gdal-dev] Compiling with OGDI on Window$
Wed Oct 20 13:03:12 EDT 2004
William Lyons wrote:
>     Hi gdal list,
>     Has anyone out there successfully compiled gdal with ogdi on window$?
William,
Yes, I have.
Were you able to build the OGDI tree without problems?  Once that is done,
OGDI enabling GDAL should be pretty easy.  Just uncomment and update the
appropriate OGDI entries in nmake.opt.  You might well need to copy the
OGDI DLLs to somewhere in your path.
Best regards,
