[Gdal-dev] Problem with reading GXF files?
Mark Coletti
mcoletti at gmail.com
Wed Oct 20 18:18:45 EDT 2004
I'm having difficulties reading a GXF file in qgis. Part of the
problem seems to be in calculating the minimum and maximum values.
For example:
qgsrasterlayer.cpp : 2062 myGdalBand->GetMinimum() failed
qgsrasterlayer.cpp : 2070 myGdalBand->GetMaximum() failed
GDALminium: -4.29497e+09
GDALmaxium: 4.29497e+09
By "failed" I mean that the pbSuccess flag was set to zero with each
of those function calls. However, the documentation for those
functions is a bit unclear as to exactly what it means with the
pbSuccess flag is zero.
pbSuccess:
pointer to a boolean to use to indicate if the returned value
is a tight maximum or not. May be NULL (default).
What is a "tight maximum?"
I've made the test file available at:
http://lychnobite.org/qgis/grvcba_gxf.gz:
Cheers,
Mark
I'm taking reality in small doses to build immunity.
