[Gdal-dev] HDF4 Driver
Fri Oct 22 10:28:53 EDT 2004
Julien Demaria wrote:
> Hi,
> I've some questions about the HDF4 support on GDAL (on Win32, Solaris
> and Linux) :
> - HDF library use libjpeg and libzip I believe : should I compile them
> separately, or should/can I use the jpeg and zip library embedded and
> used internally by GDAL ? (there aren't conflicts between libjpeg/zip
> used by HDFlib and libjpeg/zip used internally by GDAL ?)
Julien,
I was able to build against the HDF DLL which I think had an embedded
copy of libjpeg and libzip.  This seemed to work even though a heap
of code was duplicated.
Since then I wanted to build the HDF library with /MD (and without the
pseudo netcdf interface), so I did it all from the original source, building
libz and libjpeg seperately.  This was a nightmare of a job, possibly
because I approached it wrong, but I would caution against trying it unless
you have a strong need.
Note that copies of code in different DLLs is often not a bit issue on
windows as long as it isn't exported from the DLL.
Ahh, I see you are interested in solaris and linux too. I think on these
platforms the HDF libraries are willing to use external copies of libz and
libjpeg.  I have it built and it seems to be working ok.  However, on these
platforms (linux at least) duplicate copies of a library linked into the
same executable can be quite bad.
Hmm, I don't know if I have really helped very much.
I'll leave the question about georeferencing fixes to Andrey.
Best regards,
