[Gdal-dev] problems with shapefiles produced with fme translator
Ed McNierney
ed at topozone.com
Fri Oct 22 14:35:07 EDT 2004
Are you copying all three components of the shapefile - the .shp, .dbf, and .shx files? A shapefile isn't only one file.
- Ed
Ed McNierney
TopoZone.com
-----Original Message-----
From: gdal-dev-bounces at xserve.flids.com [mailto:gdal-dev-bounces at xserve.flids.com] On Behalf Of publi at infonegocio.com
Sent: Friday, October 22, 2004 2:33 PM
To: gdal-dev at xserve.flids.com
Subject: [Gdal-dev] problems with shapefiles produced with fme translator
Hi all,
I'm working in a city map, and i have an autocad files with all information. I'm using fme to translate AutoCad -> Shapefile, but i have a problem. Fme work perfectly and i can see all the files generated by it with ForestyGis, Arcview 3.3 and MapMaker 3.5. But when i copy this file to linux and i try to do "#ogrinfo -al Textos1_line.shp", the result is the next:
Unable to open datasource 'Textos1_line.shp with the following drivers:
-> ESRI Shapefile
-> UK .NTF
When i make shapefile with ArcView, no problem, ogrinfo works, and i can see it with mapserver. But when the shapefile was maden with fme, it doesn't work. The file produced by fme have 13888 features and the .shp file have 2.34 MB, Are too many????. I have installed gdal-1.2.3 and i'm working with mapserver 4.2.5 and Maplab 2.2. Why can i see it with gdal and OGR??????????. Thanks to all.
Gdal-dev mailing list
Gdal-dev at xserve.flids.com
http://xserve.flids.com/mailman/listinfo/gdal-dev
