[Gdal-dev] gdalwarp HFA color problem
Frank Warmerdam
warmerdam at pobox.com
Tue Oct 26 19:47:22 EDT 2004
Markus Neteler wrote:
> On Tue, Oct 26, 2004 at 01:50:40PM -0400, Frank Warmerdam wrote:
> Frank,
> thanks for the quick response. I did an complete recompilation, but still
> no luck. However, some changes now:
> There is still something not reaching the new color table as
> the resulting image appears almost black.
Markus,
I found one serious botch in my SetColorTable() code. You might want to check
out the latest and try again.
> And
> gdalwarp -t_srs '+init=epsg:4326' hanoi_lsat7_brovey_UTM48N.img hanoi_lsat7_brovey_LL.tif
> Creating output file is that 1482P x 2770L.
> Segmentation fault
> as before (in GDALSetRasterColorTable(), GDALWarpCreateOutput()).
> If I should upload this file somewhere please let me know.
> Otherwise it is still in the web site as indicated in the previous
> mail.
I am not getting this crash but looking through the code I can see how it
could happen. I have committed a bunch of changes in geotiff.cpp to support
writing colormaps for *16bit* data. You will find you need to force your
band type to UInt16 for this though. How a TIFF colormap should be applied
to a signed 16bit band was too confusing for me, so I stipulate in the code
that the band must be UInt16. You can use the "-ot UInt16" in your gdalwarp
call to make this happen.
I also added better error checking so datatypes for which I don't support
colormaps properly will report errors instead of doing weird and dangerous things.
All this exercise for 16bit colormaps is uncovering lots of issues!
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
