[Gdal-dev] No python support for x86_64 with kakadu?
Chris Hodgson
chodgson at refractions.net
Thu Oct 28 18:49:57 EDT 2004
>as a workaround you may try to hand edit GDALmake.opt (after configure) adding
>the support for shared libraries. search fo LD_SHARED and change it to:
>LD_SHARED = g++ -shared
>(better if you make distclean before ;)
Ok, here is the end of the compile output after setting LD_SHARED = g++
-shared (and running a make clean beforehand):
make ./libgdal.a ./libgdal.so
make[1]: Entering directory `/usr/local/src/gdal'
ar r ./libgdal.a ./frmts/o/*.o ./gcore/*.o ./port/*.o ./alg/*.o
./ogr/ogrsf_frmts/o/*.o ./ogr/ogrgeometryfactory.o ./ogr/ogrpoint.o
./ogr/ogrcurve.o ./ogr/ogrlinestring.o ./ogr/ogrlinearring.o
./ogr/ogrpolygon.o ./ogr/ogrutils.o ./ogr/ogrgeometry.o
./ogr/ogrgeometrycollection.o ./ogr/ogrmultipolygon.o ./ogr/ogrsurface.o
./ogr/ogrmultipoint.o ./ogr/ogrmultilinestring.o ./ogr/ogr_api.o
./ogr/ogrfeature.o ./ogr/ogrfeaturedefn.o ./ogr/ogrfeaturequery.o
./ogr/ogrfeaturestyle.o ./ogr/ogrfielddefn.o ./ogr/ogrspatialreference.o
./ogr/ogr_srsnode.o ./ogr/ogr_srs_proj4.o ./ogr/ogr_fromepsg.o
./ogr/ogrct.o ./ogr/ogr_opt.o ./ogr/ogr_srs_esri.o ./ogr/ogr_srs_pci.o
./ogr/ogr_srs_usgs.o ./ogr/ogr_srs_dict.o ./ogr/swq.o
./ogr/ogr_srs_validate.o ./ogr/ogr_srs_xml.o ./ogr/ograssemblepolygon.o
./ogr/ogr2gmlgeometry.o ./ogr/gml2ogrgeometry.o
ar: creating ./libgdal.a
ranlib ./libgdal.a
g++ -shared ./frmts/o/*.o ./gcore/*.o ./port/*.o ./alg/*.o
./ogr/ogr2gmlgeometry.o ./ogr/gml2ogrgeometry.o ./libgdal.a
-L/usr/local/pgsql/lib -lpq ./libgdal.a -lgif -ljpeg -lpng -lz -lm -ldl
-lkdu -L/usr/local/pgsql/lib -lpq \
-o ./libgdal.so
/usr/bin/ld: ./frmts/o/args.o: relocation R_X86_64_32 can not be used
when making a shared object; recompile with -fPIC
./frmts/o/args.o: could not read symbols: Bad value
collect2: ld returned 1 exit status
make[1]: *** [libgdal.so] Error 1
make[1]: Leaving directory `/usr/local/src/gdal'
make: *** [check-lib] Error 2
I re-made kakadu, and made certain that -fPIC was in the CC_OPTS, and it
seems to wrk correct, with -fPIC on every command line shown during the
make. Kakadu succesfully builds as a 64-bit shared library... or at
least AFAICT:
[root at dragonfly gdal]# ldd /usr/local/lib64/libkdu_v42R.so
libstdc++.so.5 => /usr/lib64/libstdc++.so.5 (0x0000002a956df000)
libm.so.6 => /lib64/tls/libm.so.6 (0x0000002a958ba000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x0000002a959bd000)
libc.so.6 => /lib64/tls/libc.so.6 (0x0000002a95ac8000)
/lib64/ld-linux-x86-64.so.2 => /lib64/ld-linux-x86-64.so.2
(0x000000552aaaa000)
I really don't know much about this stuff... being in 64-bit land makes
everything more complicated. Any more ideas or help would be great!
Thanks,
Chris
