[Gdal-dev] gdal debian package
Silke Reimer Silke.Reimer at intevation.de
Thu Sep 2 08:22:06 EDT 2004
Hi!
On Wed, Sep 01, 2004 at 03:45:02PM -0400, Frank Warmerdam wrote:
> Silke Reimer wrote:
> >Hallo!
> >Writing the mail about the gdal Fedora pacakge I remembered that the
> >debian directory is still missing the update of some rather
> >substantial changes. I still have problems with my CVS access and
> >it would be nice if you, Frank, can have another look on it.
> >Otherwise I would suggest to take the diff [1] and apply it to the CVS.
> >You will have to ensure though that it doesn't break anything that
> >has been done since the gdal 1.2.1 release.
> Silke,
> I had a few problems and issues with the changes:
> Why is this needed?
> --- gdal-1.2.1.orig/GDALmake.opt.in
> +++ gdal-1.2.1/GDALmake.opt.in
> @@ -120,7 +120,7 @@
>  # HDF4 Support.
> -HDF4_INCLUDE  = @HDF4_INCLUDE@
> +HDF4_INCLUDE  = @HDF4_INCLUDE@ -I$(GDAL_ROOT)/ogr
> It seems that this would be used in gdal/frmts/hdf4/GNUmakefile where
> the $(GDAL_INCLUDES) already includes -I$(GDAL_ROOT)/ogr.
I have to check this again. There has certainly been some reason to
add this include but I can't remember it any more. At the moment I
don't have the right system available so I hope it is OK for you to
wait with my answer.
> I also don't really understand what the HDFEOSVersion.h changes were
> supposed to do. I had trouble with auto-applying them so I tried to do
> it by hand, but looking at it more closely it seems a comparable patch
> may already have been applied.
THe HDFEOSVersion.h has been necessary to build gdal with gcc 3.4.
I looked at the email list archives and it seems indeed that this
has been fixed just after the gdal 1.2.1 release. So please drop
this change.
> I think I have applied the various other changes correctly (some by hand)
> but you might want to check.
Yes, I will recently - as soon as I have the system available again.
Thanks so far,
	Silke
Silke Reimer
Intevation GmbH                      http://intevation.de/
FreeGIS                                http://freegis.org/
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040902/4e971506/attachment.bin
