[Gdal-dev] Re: [Openev-discuss] OGR feature styles question
Wed Sep 8 12:59:08 EDT 2004
Gillian Walter wrote:
> Hi,
> The following (quite old) part of the gdal website mentions ogr feature
> style files (.OFS) under section 2.7:
> http://gdal.velocet.ca/~warmerda/projects/opengis/ogr_feature_style_008.html
> Has support for these files actually been implemented anywhere?  If so,
> did it follow this spec, or was something different done?  I am looking
> at saving layer display properties, and I'm not sure whether to make
> this support completely internal to our applications, or to try to do
> something that could also be used in OpenEV.
Gillian,
The advanced OpenEV rendering capabilities are implemented according to the
OGR Feature Style document though it is by no means a complete implementation
of the specification.   However, within OpenEV the feature style strings
are stored in a _gv_ogrfs attribute on the features.  The OGR reader takes
care of reading the feature style from an OGRFeature and turning it into an
_gv_ogrfs attribute.
There isn't really much capability in OGR or OpenEV for saving the _gv_ogrfs
stuff in arbitrary output files.  Ideally the shapefile saver would add a
column for it if it is present in the dataset but that has no been done.  The
project saved logic *does* preserve the _gv_ogrfs.
My suggestion is to save the feature style as a regular attribute called
_gv_ogrfs for your application purposes.
Best regards,
