[Gdal-dev] MrSID Segmentation Fault
Simpson
asimpson at i-55.com
Thu Sep 9 13:27:27 EDT 2004
I tried to compile both gdal-1.2.1 and gdal-cvs-20040903 with the
libgeotiff-1.2.1 on my system and the compilation failed with:
(cd ogr; make apps)
make[1]: Entering directory `/xxx/Software/gdal-cvs-20040903/ogr'
/bin/sh ../libtool --mode=compile
g++ -Wall -O2 -Iogrsf_frmts -I. -I../port -I../gcore -I../ogr -I../alg
-D_REENTRANT -I../port -c -o ogrinfo.o ogrinfo.cpp
g++ -Wall -O2 -Iogrsf_frmts -I. -I../port -I../gcore -I../ogr -I../alg -D_RE
ENTRANT -I../port -c ogrinfo.cpp -fPIC -DPIC -o .libs/ogrinfo.o
ENTRANT -I../port -c ogrinfo.cpp -o ogrinfo.o >/dev/null 2>&1
/bin/sh ../libtool --mode=link g++ ogrinfo.o ../libgdal.la -o ogrinfo
g++ ogrinfo.o -o .libs/ogrinfo
../.libs/libgdal.so -lodbc -L/usr/local/Geo_DSDK-4.0.9.713/lib/Release -llti
dsdk -lpthread -ljasper -lgif
/usr/lib/libjpeg.so -lgeotiff -ltiff -lpng -lz -ldl -L/usr/lib -lpq
../.libs/libgdal.so: undefined reference to `gtCSVReadParseLine'
collect2: ld returned 1 exit status
make[1]: *** [ogrinfo] Error 1
make[1]: Leaving directory `/xxx/Software/gdal-cvs-20040903/ogr'
make: *** [ogr-apps] Error 2
If I used the configure parameter "--with-geotiff=internal" gdal compiled
cleanly.
I downloaded and installed libgeotiff-1.2.2 and now gdal compiles cleanly,
but didn't fix problem with MrSID.
Here is gdb output from running gdalinfo against one of the problem MrSID
files:
(gdb) run n_16_30_2000c.zu.sid
Starting program: /usr/local/bin/gdalinfo n_16_30_2000c.zu.sid
Program received signal SIGSEGV, Segmentation fault.
0x40266eda in LizardTech::LTISample::getValueFloat32() const ()
from /usr/local/lib/libgdal.so.1
(gdb) bt
#0 0x40266eda in LizardTech::LTISample::getValueFloat32() const ()
#1 0x4014ff6f in MrSIDRasterBand::MrSIDRasterBand(MrSIDDataset*, int) ()
#2 0x40150f51 in MrSIDDataset::OpenZoomLevel(int) ()
#3 0x4015132b in MrSIDDataset::Open(GDALOpenInfo*) ()
#4 0x40182abd in GDALOpen () from /usr/local/lib/libgdal.so.1
#5 0x08049833 in main ()
#6 0x42015967 in __libc_start_main () from /lib/i686/libc.so.6
(gdb)
Thanks for your help,
Drew.
-----Original Message-----
[mailto:gdal-dev-bounces at xserve.flids.com]On Behalf Of Andrey Kiselev
Sent: Tuesday, September 07, 2004 2:22 PM
To: gdal-dev at xserve.flids.com
Subject: Re: [Gdal-dev] MrSID Segmentation Fault
On Tue, Sep 07, 2004 at 10:54:53AM -0500, Simpson wrote:
> I have successfully got gdal utilities to process the majority of my sid
> files, but landsat data from https://zulu.ssc.nasa.gov/mrsid/ is getting
> segmentation fault. The MrSID utilities mrsidinfo and mrsiddecode seem to
> work properly with these datasets. The one I've been playing with is
https://zulu.ssc.nasa.gov/mrsid/bin/download_file.pl?client=etmpsmos/sid&ima
> ge=N-16-30_2000.tar , if you can get through to the site. Any
> tips/suggestions would be great.
Drew,
I shall try to reproduce your problem tomorrow. Just a single question:
what GDAL version you are working with?
> The geotiff on the system would not compile so used version that
> came with gdal.
That problem is interesting for us too. Why you can't compile
libgeotiff?
> STRACE Of gdalinfo call
Well, thanks for your output, but gdb results will be really more useful
for us...
Regards,
Andrey
Andrey V. Kiselev
Home phone: +7 812 5274898 ICQ# 26871517
Gdal-dev mailing list
Gdal-dev at xserve.flids.com
http://xserve.flids.com/mailman/listinfo/gdal-dev
