[Gdal-dev] Undefined Symbol: CPLCreateThread
Christian G. Tveen
cgt at navicon.dk
Tue Sep 14 18:48:00 EDT 2004
In port/cpl_multiproc.cpp, you may try to set
CPL_C_START before CPLCreateThread, and CPL_C_END after CPLCreateThread:
CPL_C_START
CplCreateThread ()
CPL_C_END
If this does not help, its due to my bad memory, and I'll have to check
my solution at the Solaris box at work tomorrow.
Best Regards Christian
Frank Warmerdam wrote:
> Dan wrote:
>> Hi,
>> I am trying to link my solaris application with the GDAL libs (still
>> using 1.1.9) using Sun Forte CC, and my final undefined symbol error
>> i receive is for CPLCreateThread, referenced from the
>> gdalwarpoperation.o file in the GDAL library...is there a library i
>> need to include prior to including GDAL for this symbol to be
>> defined??? Any help is appreciated...thanks..
> Dan,
> I'm not sure why this is happening to you. CPLCreateThread() should be
> defined in cpl_multiproc.cpp. If pthreads or win32 style stuff isn't
> available it should fallback to a dummy implementation.
> If you can't easily identify what is going wrong in cpl_multiproc.cpp,
> you
> can just comment out the call in gdal/alg/gdalwarpoperation.cpp. Multi
> threading is not normally used.
> PS. 1.1.9 is pretty ancient. It's alot more fun answering questions
> about
> current software.
> Best regards,
