[Gdal-dev] TIFF Compressions Disabled (Unix)
Julien Demaria
dem at acri-st.fr
Wed Sep 22 09:50:44 EDT 2004
Frank,
should I also add the other options from makefile.vc (fillorder, stripchop,
extrasample, ycbcr_subsampling, $(jpeg_flags)) ? :
in makefile.vc :
EXTRAFLAGS = -I..\..\zlib -DFILLODER_LSB2MSB \
-DCCITT_SUPPORT -DPACKBITS_SUPPORT -DLZW_SUPPORT \
-DTHUNDER_SUPPORT -DNEXT_SUPPORT -DLOGLUV_SUPPORT \
-DZIP_SUPPORT -DPIXARLOG_SUPPORT \
-DSTRIPCHOP_DEFAULT=TIFF_STRIPCHOP \
-DDEFAULT_EXTRASAMPLE_AS_ALPHA
-DCHECK_JPEG_YCBCR_SUBSAMPLING \
$(JPEG_FLAGS)
Thanks,
Julien
At 15:26 22/09/2004, Frank Warmerdam wrote:
>Julien Demaria wrote:
>>Hi,
>>Maybe I'm wrong but it seems that at least PACKBITS and LZW TIFF
>>compressions are disabled under Unix in the current GDAL CVS (and in
>>1.2.2 version) :
>>in frmts/gtiff/libtiff/GNUmakefile only pass the -DZIP_SUPPORT
>>-DPIXARLOG_SUPPORT -DJPEG_SUPPORT
>>and the makefile.vc pass -DCCITT_SUPPORT -DPACKBITS_SUPPORT -DLZW_SUPPORT \
>> -DZIP_SUPPORT -DPIXARLOG_SUPPORT -DJPEG_SUPPORT
>Julien,
>I am afraid you are quite correct. I had noticed this and talked to Andrey
>about it briefly, but then I forgot to ensure it was corrected before the
>release.
>In the meantime I believe you can just add the extra defines in the
>gdal/frmts/gtiff/libtiff/GNUmakefile.
>Change:
>ALL_C_FLAGS = $(CFLAGS) -DZIP_SUPPORT -DPIXARLOG_SUPPORT
>-I../../zlib
>to:
>ALL_C_FLAGS = $(CFLAGS) -I../../zlib \
>I have created a bug report to track this problem:
> http://208.24.120.44/show_bug.cgi?id=616
>I will try to issue a GDAL 1.2.3 within a few weeks since this is a fairly
>noteworthy flaw in 1.2.2.
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | Geospatial Programmer for Rent
