[Gdal-dev] Create method
Frank Warmerdam
warmerdam at pobox.com
Fri Sep 24 10:28:01 EDT 2004
Julien Demaria wrote:
> Frank,
> I think this is incompatible with the GDAL API, but would it be possible
> (theoritically) to provide a "limited write only" approach in which we
> give all the file format informations (colortable, geolocation, nodata,
> ...) only one time at the create call (a CreateSimple method ?), and
> allow only to write in sequential line-by-line way ?
> This approach could be implemented easily for many more drivers than the
> standard Create approach, isn't it ?
Julien,
Yes, I can see that this might be desirable, but I'm not too keen on yet
another way of creating files. Note, that you can provide a virtual file
as input which provides callbacks to get the image data if you want to
avoiding having a copy of the imagery already exist somewhere.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
