[Gdal-dev] pb creating a bmp
Stephane Routelous
route at cae.com
Mon Sep 27 15:11:45 EDT 2004
i'm using GDAL 1.2.2.0, released 2004/08/16 on Windows 2000 with
VisualC++6.0 SP5
I was working with bmp file :
void testGDAL()
GDALAllRegister();
GDALDriver *poDriver;
char **papszMetadata;
poDriver = GetGDALDriverManager()->GetDriverByName("BMP");
if( poDriver == NULL )
return;
papszMetadata = poDriver->GetMetadata();
if( !CSLFetchBoolean( papszMetadata, GDAL_DCAP_CREATE, FALSE ) )
printf( "Driver %s does not support Create() method.\n" );
return;
int x = 40;
int y = 40;
GDALDataset* m_gdalDataSet = poDriver->Create( "T:\\foo.bmp", x, y, 3,
GDT_Byte, NULL);
if ( m_gdalDataSet == NULL )
return;
GDALRasterBand *poBand = m_gdalDataSet->GetRasterBand(1);
if ( poBand == NULL )
return;
unsigned char* value = (unsigned char*)malloc(x*y);
memset(value,255,x*y);
CPLErr err = poBand->RasterIO( GF_Write, 0, 0, x, y, value, x, y,
GDT_Byte, 0, 0 );
free(value);
if ( err != CE_None )
return;
m_gdalDataSet->FlushCache();
GDALClose(m_gdalDataSet);
as output (in stdout) I have :
ERROR 3: Can't write block with X offset 0 and Y offset 0
ERROR 3: Can't write block with X offset 0 and Y offset 1
ERROR 3: Can't write block with X offset 0 and Y offset 2
ERROR 3: Can't write block with X offset 0 and Y offset 3
ERROR 3: Can't write block with X offset 0 and Y offset 33
ERROR 3: Can't write block with X offset 0 and Y offset 34
RasterIO returns CE_None and the created file is wrong.
can you help me with this problem ?
I tried to check the gdal code when debugging, but I'm lost.
Thanks in advance,
Stephane
