[Gdal-dev] netcdf reading problems
Tim Sutton
tim at linfiniti.com
Thu Sep 30 09:21:51 EDT 2004
Hi
I am trying to read netcdf data with gdal so that I can convert it to ascii
format, and to be able to view it in QGIS. I found that gdal wont read
any .nc files I give it. The data I am trying to read is multiband (e.g.
http://linux-gis.co.uk/climate_sample.nc), but even a simple single band
layer (http://linux-gis.co.uk/simple.nc) wont read. Iget error message like
this from gdal:
aps02ts at linux:/tmp/netcdf_tests> gdalinfo simple.nc
ERROR 4: `simple.nc' not recognised as a supported file format.
GDALOpen failed - 4
My gdal is built against cvs head:
aps02ts at linux:/tmp/netcdf_tests> gdalinfo --version
GDAL 1.2.2.0, released 2004/08/16
And has netcdf support compiled in :
aps02ts at linux:/tmp/netcdf_tests> gdalinfo --formats
Supported Formats:
8<----------- snip-----------------
netCDF (rw): network Common Data Format
And the netcdf lib I am using is a suse rpm:
aps02ts at linux:/tmp/netcdf_tests> rpm -qa |grep netcdf
netcdf-3.5.0-665
I have tested the sample data with a standlone netcdf viewer (ncview) and it
is able to read the data without problem.
Any help you can offer will be greatly appreciated!
Regards
Tim Sutton
The only reason for time is so that everything doesn't happen at once
--Albert Einstein
Get my public keys from:
http://tim.suttonfamily.co.uk/modules.php?name=Content&pa=showpage&pid=2
