[Gdal-dev] Get a pixel from a lat/lon.
Ken Sewell
sewell at dramail.com
Thu Sep 30 11:11:16 EDT 2004
We're basically using the same code in the gdalinfo.c. We're still
very new at using GDAL so how we go about reversing this to get the pixel
from a lat/lon is still not obvious. Basically we just need to go both
directions pixel to lat/lon and lat/lon to pixel, we used this method
because we found it in an example. Can anyone recommend a better way to
accomplish what we need to do? Thanks.
if( GDALGetGeoTransform( hDataset, adfGeoTransform ) == CE_None )
pszProjection = GDALGetProjectionRef(hDataset);
dfGeoX = adfGeoTransform[0] + adfGeoTransform[1] * x
+ adfGeoTransform[2] * y;
dfGeoY = adfGeoTransform[3] + adfGeoTransform[4] * x
+ adfGeoTransform[5] * y;
if( pszProjection != NULL && strlen(pszProjection) > 0 )
OGRSpatialReferenceH hProj, hLatLong = NULL;
hProj = OSRNewSpatialReference( pszProjection );
if( hProj != NULL )
hLatLong = OSRCloneGeogCS( hProj );
if( hLatLong != NULL )
CPLPushErrorHandler( CPLQuietErrorHandler );
hTransform = OCTNewCoordinateTransformation( hProj, hLatLong
CPLPopErrorHandler();
OSRDestroySpatialReference( hLatLong );
if( hProj != NULL )
OSRDestroySpatialReference( hProj );
if( hTransform != NULL
&& OCTTransform(hTransform,1,&dfGeoX,&dfGeoY,NULL) )
printf( "(%s,", GDALDecToDMS( dfGeoX, "Long", 2 ) );
printf( "%s)", GDALDecToDMS( dfGeoY, "Lat", 2 ) );
if( hTransform != NULL )
OCTDestroyCoordinateTransformation( hTransform );
Ken Sewell Defense Research Associates
Project Engineer 3915 Germany Lane, Suite 102
937-656-4899 x3004 Beavercreek, Ohio 45431-1608
On Wed, 29 Sep 2004, Frank Warmerdam wrote:
> Ken Sewell wrote:
> > Given a lat/lon can GDAL tell me what pixel is associated with it(if
> > any)? I've found the function that will give me the lat/lon from the
> > pixel, but I can't seem to find one that gives me a pixel from a lat/lon?
> > Does such a function exist within GDAL? Thanks.
> Ken,
> Generally speaking, going from lat/long to pixel is the same process as
> going from pixel to lat/long. Can you show how you are doing from
> pixel to lat/long?
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
