[Gdal-dev] GDAL and ECWP
Frank Warmerdam fwarmerdam at gmail.com
Fri Apr 1 16:56:30 EST 2005
On Apr 1, 2005 4:26 PM, Brent Fraser <bfraser at geoanalytic.com> wrote:
> Frank,
>  Does gdal_translate work with ecwp?  For example, when running:
> gdal_translate -of GTiff "ecwp://apps.minerals.nt.gov.au/ntgs
> ecwp/NT/TMICol.ecw" test.tif
> I get:
> Input file size is 10578, 17161
> 0.ERROR 1: TryWinRasterIO() failed for blocked scanline.
> ERROR 1: IReadBlock failed at X offset 0, Y offset 0
> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
> Are some enhancements needed to make it work?
Brent,
Once upon a time the ecwp protocol seemed to be working more-or-less
but for some reason would sometimes get screwed up and not recover.
But I haven't tried it in ages, so no doubt it is completely broken now.
No fault of the ECW SDK - I would guess it is stuff I am doing wrong.
Hmm, I could be getting a bit mixed up with the jpip protocol.
You can file a bug report on this, but it isn't honestly too high a priority
for me just now.
Best reagards,
