[Gdal-dev] More problems compiling under VS.NET 2003
    Thom DeCarlo
    t.r.decarlo at larc.nasa.gov
    Tue Apr  5 14:57:55 EDT 2005
I did a full install of VS.NET 2003 and that file did not make it onto my
computer. I'll poke around some more to see if any component was skipped,
but I don't think that is the case.
Thom
Thom DeCarlo
       If a tree falls in a virtual forest
      and it's not in anyone's field of view,
               does it really happen?
> -----Original Message-----
> From: Bart van den Eijnden
> Sent: Tuesday, April 05, 2005 2:37 PM
> To: Thom DeCarlo; 'gdal-dev'
> Subject: Re: [Gdal-dev] More problems compiling under VS.NET 2003
> Afrex.h is part of MFC. Did you install that with Visual Studio? Is it in
> your include path (...../MFC/include)?
> Rc is a utility to put version info (version number etc.) into a dll or
> application.
> Best regards,
> Bart
> On Tue, 5 Apr 2005 14:30:12 -0400, Thom DeCarlo
> > Hello,
> > I pulled down last night's cvs tarball and tried to compile. The build
> is
> > crashing in gcore when it tries to execute:
> >         rc -fo Version.res -r -I..\port Version.rc
> > Version.rc(1) : fatal error RC1015: cannot open include file 'afxres.h'.
> > NMAKE : fatal error U1077: 'rc' : return code '0x1'
> > Stop.
> > The file Version.res is new to me. (The last tarball I downloaded was
> > from
> > 20041221.) I'm not really sure what it is supposed to do, but there is
> no
> > afxres.h anywhere on my computer.
> > Can anyone who has had luck building under VS.NET'03 tell me how they
> > managed it?
> > Thanks,
> > Thom
