[Gdal-dev] More problems compiling under VS.NET 2003
Bart van den Eijnden
bartvde at xs4all.nl
Tue Apr 5 15:08:20 EDT 2005
Hi Frank,
apparently you can just edit the rc file and replace afxres.h with
winres.h. That should solve it.
Best regards,
Bart
On Tue, 5 Apr 2005 15:02:44 -0400, Frank Warmerdam <fwarmerdam at gmail.com>
wrote:
> On Apr 5, 2005 2:57 PM, Thom DeCarlo <t.r.decarlo at larc.nasa.gov> wrote:
>> I did a full install of VS.NET 2003 and that file did not make it onto
>> my
>> computer. I'll poke around some more to see if any component was
>> skipped,
>> but I don't think that is the case.
> Thom,
> If you can't find the file, you can just remove Version.res from
> gdal/makefile.vc (the link line) and gcore/makefile.vc and things
> should work fine. You just won't get detailed versioning in the DLL.
> If there is a cleaner way of building this resource file I would
> be interested to hear. Of course, it is problems like this that
> normally
> prevents me from doing anything progressive like using resource
> files.
> Best regards,
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
