[Gdal-dev] More problems compiling under VS.NET 2003
Thom DeCarlo
t.r.decarlo at larc.nasa.gov
Tue Apr 5 15:20:32 EDT 2005
Frank,
I'm not sure why the file didn't turn up in the first search, but I found it
in ...../Vc7/atlmfc/include, which was not in my include path. I've added
that and am pressing on...
Thanks,
Thom
Thom DeCarlo
Do Not Meddle in the Affairs of Dragons
For You are Crunchy and Taste Good with Ketchup
> -----Original Message-----
> From: Frank Warmerdam
> Sent: Tuesday, April 05, 2005 3:03 PM
> To: Thom DeCarlo
> Cc: gdal-dev
> Subject: Re: [Gdal-dev] More problems compiling under VS.NET 2003
> On Apr 5, 2005 2:57 PM, Thom DeCarlo wrote:
> > I did a full install of VS.NET 2003 and that file did not make it onto
> my
> > computer. I'll poke around some more to see if any component was
> skipped,
> > but I don't think that is the case.
> Thom,
> If you can't find the file, you can just remove Version.res from
> gdal/makefile.vc (the link line) and gcore/makefile.vc and things
> should work fine. You just won't get detailed versioning in the DLL.
> If there is a cleaner way of building this resource file I would
> be interested to hear. Of course, it is problems like this that normally
> prevents me from doing anything progressive like using resource
> files.
> Best regards,
