[Gdal-dev] Kakadu and MrSID conflict
Kenneth Melero
kmelero at sanz.com
Wed Apr 6 12:36:10 EDT 2005
Julien,
Unfortunately there is no fix for the moment with configuring both MrSID and
Kakadu at the same time other than obtaining a MrSID release from Lizrdtech
that does not contain Kakadu in its internal libraries.
To turn on MrSID SDK for both .sid and .jp2 files read this previous thread:
http://xserve.flids.com/pipermail/gdal-dev/2005-March/008304.html
-Ken
-----Original Message-----
[mailto:gdal-dev-bounces at xserve.flids.com] On Behalf Of Frank Warmerdam
Sent: Wednesday, April 06, 2005 9:44 AM
To: Julien Demaria
Cc: gdal-dev at xserve.flids.com
Subject: Re: [Gdal-dev] Kakadu and MrSID conflict
On Apr 6, 2005 3:32 AM, Julien Demaria <dem at acri-st.fr> wrote:
> I found that last MrSID DSDK is Kakadu v4.2 based ; so I'll try to
> downgrade my Kakadu to v4.2...
> Are there solutions to this conflicts ?
Julien,
The only "solution" I am aware of is to drop the Kakadu out of the build,
and depend on the MrSID driver for JPEG2000 support. However, I am not sure
if the GDAL MrSID code is really setup properly to handle JPEG2000. In
fact, I haven't personally run into this yet since I don't normally build
with the MrSID SDK.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
Gdal-dev mailing list
Gdal-dev at xserve.flids.com http://xserve.flids.com/mailman/listinfo/gdal-dev
